Ga door naar hoofdinhoud
Model A1369, 1.6, 1.7, or 1.8 GHz Processor, 64, 128 or 256GB Flash Storage
No Keyboard function after reassembly
Hi there
I spilled some gin on my Macbook, immediately opened it, cleaned it with a paper towel to dry and then with some IPA.
Heres the thing, except the Keyboard, wich worked before, everything seems fine.Even the Backlight of the Keyboard is working properly
cheers Guys
Is dit een goede vraag?
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
There are numerous videos on how to replace just the keyboard on this model. Lots of labor but only about $25 for a good part. Here’s one:
how to replace the keyboard on a macbook air 2011
Was dit antwoord nuttig?
Score 2
Did you have some tonic water with it and the Lime? :-/
Sorry to say you’ll need to replace the uppercase to fix this MacBook Air 13" (Mid 2011) Upper Case with Keyboard. Here’s the guide you’ll need to follow MacBook Air 13" Mid 2011 Upper Case Replacement
Replace an upper case assembly compatible with the Mid 2011 MacBook Air 13 inch laptop. Includes the keyboard, palmrest area, and power button. Afbeelding
Product
$49.99
Score 1
Hey mate
Id recommend removing your motherboard and cleaning it.
Drying out water damage is really what you want to avoid, your only speeding up the corrosion process. The board needs to be cleaned not dried.
You can use Isoprophyl Alcohol and a toothbrush at the very least.
or EC cleaner & distilled water
Score 1
Voeg je antwoord toe
Andreas Schmid zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 13
Altijd: 125
