Ga door naar hoofdinhoud
Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
20 Vragen Bekijk alle
Do I need logic board silver ground strap?
There is a gap in the otherwise excellent instructions on this site in regards to replacing my iPod's logic board. What do I do about the silver ground strap that remains attached to my old logic board once I've completed all the instructions?
One post on this site says you don't need it. Another says you do.
I'm assuming I need it since, after all, my iPod came with it. I've managed to pry the old one off and attach it to my new logic board. However, it seems to me this gap in the instructions should be filled.
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
+Honestly I have just changed two of the boards and did not use the ground strap and it did not cause any problems on the iPods. You are absolutely right, if and when you can get it of the old logic board, it is always wiser to apply it to the new one. Did you write a note on the instructions? That way others will become aware of it. good observation...;-)
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Thank you for accepting my answer and wishing you years of fun with your iPod.
door
Voeg je antwoord toe
adamorth zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 2,703
