Ga door naar hoofdinhoud
Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Vragen Bekijk alle
Screen brightens when pressed
Whenever I press the phone near where the connecters are it brightens and when I let go it dims; I have connected and disconnected the connecters multiple times
Is dit een goede vraag?
3 opmerkingen:
Sounds like a backlight issue. have you tried the original display?
door
My bet is you purchased a replacement screen that isn't very high quality. When you press the screen, the backlight layer of the display is coming closer to the screen surface which makes it appear brighter.
door
@salad Probably a low quality display as Steve Godun said, try the original display if you still have it and report back to us. :)
door
Voeg een opmerking toe
1 Antwoord
Make sure the metal plate is tight, and make sure you have foam pads on the connectors. (You can transfer them over from the original)
Was dit antwoord nuttig?
Voeg je antwoord toe
Axel Salas zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 31
