A/c compressor fuses and relay located
On an 88 honda accord where are the fuses for the a/c compressor and the relay for it located on the car
Is dit een goede vraag?
you’ll have to check Fuse #5 which is the fuse for the clutch relay. The clutch relay should be in the engine compartment on the left fender behind p/s fluid reservoir. There should be two relays. One is for the condensor and the other one for the a/c clutch.. The one with a red wire on the connector is for the AC.
Was dit antwoord nuttig?
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 25
Afgelopen 30 dagen: 88
Altijd: 4,377
