Ga door naar hoofdinhoud
The Dodge Challenger Concept was unveiled at the 2006 Detroit Motor Show and was a preview for the 4th generation Dodge Challenger that started its production in 2008. Many design cues of the Dodge Challenger Concept were adapted from the 1970 Dodge Challenger R/T.
11 Vragen Bekijk alle
Tach sitting below zero
just bought a 2010 Challenger R/T last week. I am in the process of installing my radio from my old car into this one. I pulled the instrument cluster to run the microphone wire behind it. Long story short... I went to put it back together and noticed that the gauges were sitting below all the markings. I got everything reset. But now the tach is sitting below zero rpms even when i turn the key on. I have tried resetting the cluster with the trip button. It doesn't help, i manually rest it back to zero with the key on. I turn the key back off and it stays good for about 5 minutes then it falls back below zero and doesn't come back up when i turn the key back on. Need some help on how to get it to sit right. This is the last thing i have left before i can finish putting the car back together.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Did you check all your fuses?
Was dit antwoord nuttig?
1 Opmerking:
I just seen the date that you posted that. what was the problem?
door
Voeg je antwoord toe
Joshua Johnson zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 4
Altijd: 107
