Ga door naar hoofdinhoud
The HP Split x2 is a 13" hybrid tablet/laptop combination was sold in mid-2013. The HP split is easily identified by its pull apart design.
18 Vragen Bekijk alle
Why is my the battery on the bottom half of my device draining quick.?
I have the hp split x2 model 13-m210dx , and the bottom half of it is running out of battery extremely quick. I really want to know where can I find another bottom half to the device to replace or how can I fix the battery.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi,
The battery in the keyboard dock may be failing and it may have to be replaced or perhaps it may just have to be recalibrated.
Try using the HP PC Hardware diagnostics program to test if the battery is OK or if it just needs to be recalibrated if it is not faulty
If it is not already installed in the tablet/laptop, here’s a link to the service manual for your tablet/laptop, taken from this webpage. Scroll to p.77 in the service manual to view how to download and run the program.
If the battery is faulty, scroll to p.37 to view the necessary pre-requisite steps and then the procedure to remove/replace the battery.
Also on p.37 you’ll find the part number (725607-001 ) for the battery.
If you search online, using the part number only, you’ll get results for suppliers of the part.
Hopefully this is of some help.
Was dit antwoord nuttig?
Score 3
Voeg je antwoord toe
mario661962 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 107
