Ga door naar hoofdinhoud
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Vragen Bekijk alle
iPhone 3GS Silent switch is not working
Hello,
I have a two years old iphone 3GS. The silent switch on the phone does not work. When I push the switch to silent mode, it goes to silent mode for a second.And as soon as I take my figure of the switch it turns back to ringer mode. I am sure the switch snaps and it clicks when I push it down. It seems like I have to press the switch inside to hold it into silent mode and whenever I take my figure off it I get backs to ringer mode. When I put the phone in my pocket for the slightest of touch is start to toggle between silent and ringer mode. So, basically I have to press the switch inside when it is in silent mode to make it got to silent. I have looked up some of the questions, but I was not sure if I have to replace the head jack or if it is just a connector issue.
Thank you for all your help.
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
you have 2 choices as you said.. you can either take the phone apart to look at the tiny toggle that turns the phone to silent and see if it is just not sitting in the groove of the outer switch (the bit you have to keep holding down) my guess is that this is the problem or it has worn down with 2 years of use.
you can try a bit of fix with something to make the toggle stay in it's groove or replace the part and know that the problem is solved. depends how much money you want to spend... replacing the jack can be a PITA with the power button but if you play about with the screws that hold the power button in you can make sure it works. let us know how you get on. all the best, jen
Was dit antwoord nuttig?
Score 1
1 Opmerking:
So, can I use this manual iPhone 3GS Mute Button Replacement to take my phone apart and check the silent switch. Please let me know I am looking at the correct manual.
Thank you for all your time.
door
Yes thats the correct manual, you don't have to take the power button portion out, actually just taking the screws out in steps 17 and 18 will allow you to slide out the silent switch and you can try to re-set it with out removing any other parts.
2 opmerkingen:
It's a bit pushed for space.... You don't have to dismantle all the phone/flexes but taking the logicboard out let's you get to the screws. The guide is just that...
door
Thank you guys for all your answers. I will get the tools and try it out and will update you soon.
Thanks.
door
i have this problem too and it isn't the outside button you have to open up your iphone. or send it back too apple and let it repair for about 30 euro :( .
Voeg je antwoord toe
switchbreaker zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 26,447
