Ga door naar hoofdinhoud
De Keurig K55 koffiemachine is te herkennen aan het modelnummer K55 Classic Series. De K55 werd uitgebracht op 2 december 2015 en ondersteunt zowel K Cups als traditionele gemalen koffie. Dit product is compatibel met stopcontacten die 120 volt ondersteunen en heeft mogelijk een converter nodig bij gebruik buiten de Verenigde Staten.
No power into machine
I recently bought a Keurig K55 from bed baths and beyond. I was falsely sold this item by the sales rep. I asked if the machine would work in the uk and I was told to put a 3 pin adapter on the end of the plug and it would be fine. I done exactly this it started hearing the water and then suddenly stopped. Can I be told how to fix this and if I should use a voltage dropper convertor?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Het nuttigste antwoord
Hi @veepatel
Confirm the input voltage on your Keurig K55
there should be a label mentioning about input voltage, e.g. 110V
In UK, voltage is supplied at 230V....
If your device is labelled at 110V and you connect it to 230V, likely is could be damaged.
I think you mean step down voltage transformer (drop voltage from 230V to 110V), you need to consider on your coffee maker power consumption also. Not all converter might be suitable of this.
update us first on your current machine voltage input.
Was dit antwoord nuttig?
Score 3
5 opmerkingen:
I'm guessing I have damaged it. Yes the voltage is 110v. Is there anyway of repairing it?
door
Hi @veepatel
Well you may try opening up and check, hopefully would be just the power supply section is damaged.
take and share some pics with us
door
Sure will do when I get home from work. Thanks for ur help
door
Hi please find a picture below.
door
Does anyone which power supply I have to buy as in model number etc...
Thanks
door
Afbeelding
here is the picture
Voeg je antwoord toe
Vishal Patel zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 22
Altijd: 1,138
