Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Instapmodel Photosmart-printer geïntroduceerd in 2009. Maakt gebruik van HP Tri-Color inktcartridges met een wegwerpprintkop.
Scan Failure on second attempt.
I can print one copy after I turn the printer on. A second attemp will give me a “Scan Failure”. I restart the printer and the same thing happens. If I try to Scan, I get the overview ok but The scan failure comes up if I try to scan. I looks like the scanner is not returning to the idle position after a first scan.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Filteren op:
Gekozen oplossing
It sounds like your reading head for your scanner is not returning to it’s “home” position. If you are halfway not fumble-fingered like me, you can gin entry by usually removing the top glass. You should be able to get the head into it’s '‘home” position and check the cogged belt that moves it to determine if the belt just jumped a notch or if you have worn belt or stepper-motor problems. Check for a mark on the belt made by a marker at the factory when your unit was first set up. This will help you determine what’s going on. If it checks out mechanically, try reloading your driver software for the HP. And be careful around any of the printer’s so-called “secure” home pages for software downloading—-they seem to be a heavily targeted area for con artists with their own software and programs.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
jnmstuff zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 10
Altijd: 301
