Ga door naar hoofdinhoud
Repair guides and support for your LG TV.
1343 Vragen Bekijk alle
No Power / No Standby Light (already tried PS Board) LG 47LA6200
Can someone suggest what to try next?
TV is an LG 47LA6200-UA.
Symptoms are: NO power at all. Not even the red LED standby light.
I already tried TWO replacement power supply boards and Nothing.
Still, no power at all and not even the red LED standby light. (See photos).
(I also tried a new power cord just in case - but nothing)
What should I try next?
Is it possible that the mainboard is the issue?
NOTE: I can probably dis-assemble and replace parts, but I’m NOT a technician and I don’t have sophisticated test equipment.
Thanks!
David
Is dit een goede vraag?
Score 1
3 opmerkingen
FIXED!
The mainboard was the issue. I swapped out the mainboard and TV works great!
Thanks again for everyone’s help!
door
Lg 4K tv no power no red light on completely dead
help … help
door
Hi,
I think you would need to FIRST swap out the power supply board.
If that doesn't help, then the motherboard.
I had to change BOTH of those boards to get my TV working
DF
door
Voeg een opmerking toe
4 Antwoorden
Gekozen oplossing
FIXED!
I swapped out the mainboard and the TV works great!
Thanks again for everyone’s help.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Hey my tv power board blinks and 3-4 times after video goes out
Same model
door
Het nuttigste antwoord
@djordan
yes it is absolutely possible. Since you already repalced the power board it is most likely a main board or a button bar/IR board issue. Start by measuring the voltage right at the fuse on your power board. This will make sure that you have power going to the board (just out of curiosity, you did check your outlet and tried a different outlet as well)
Score 4
2 opmerkingen:
Thank you irineo and oldturkey!
Excellent diagram oldturkey! I’m going to measure as you’ve directed when I have access again to the TV over next few days (at a buddy’s place). I might also order a mainboard to try it to see what happens.
(Also, confirmed that our power outlet is working - we tried at least a couple and other devices were plugged into the power bar).
Will report back - thanks again.
door
I know this post is old, but I have the same TV, different symptom...Power is on, audio works, but video flashes off/on - even when using the setup menu. This continues after disconnecting all video inputs and leaving unplugged overnight to drain any residual power. I'm pretty certain from all the electrolytic capacitors in the pics of the power supply that some/all of them may be damaged. Can anyone verify this? Thanks so much!
door
NEXT TROUBLESHOOTING STEPS?
Both the ORIGINAL board and the FIRST replacement board test properly (at the indicated test points)… (I didn’t test the SECOND replacement board because it didn’t have the same test points accessible on the power connector):
  • Finally set the TV up for testing on my table…
*** ORIGINAL BOARD TESTING: First and Second test points:
  • FIRST REPLACEMENT BOARD TESTING: First and Second test points:
  • NOTE: Just to be sure I have the correct boards, I took close-ups of each. There seem to be minor differences. For example my ORIGINAL board is marked with “IT” (on the lower bottom edge per the photo); and the FIRST replacement board is marked “HE”. Not sure if that matters
ORIGINAL BOARD
SECOND REPLACEMENT BOARD
Score 3
david , if you have multi tester check dc volts output at psu in between connection of psu and the mainboard if nothing the power supply is dead or same with that you bought … if there is supposed to be have standby lights ..
Score 2
Voeg je antwoord toe
David Friedman zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 51
Altijd: 27,878
