Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
2690 Vragen Bekijk alle
Phone screen not working
The screen is black but is still lit up when I press any button, I can still press things and I hear it responding like when I touch it to put the passcode. It makes the key noises. But the screen won’t display anything. How can I fix it at home
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
You tried Resetting the device obviously i assume.
Was it dropped? Did it go into water? Was it bent?
Sounds like a bad screen, There should be guides, and i believe the tools you would need to replace the screen on this site here.
Was dit antwoord nuttig?
can you tell us what you were doing prior to the black screen? Is the phone hot? is your phone damaged in anyway (software - memory at full capacity, outdated firmware, hardware - dropped it, used a really really off brand charger that messed up the motherboard)
If you want to fix it at home, I would first plug it in your computer and check on itunes to see if your computer recognizes your device. If so, back it up and do a factory reset or restore it to a previous time when your phone was working.
if neither of these work, open up your phone and check the screen digitizer circuits and your battery. what do i mean by battery? you could have a faulty battery (therefore it’s swollen and beginning to press up against the motherboard, causing issues)
Voeg je antwoord toe
daphne morffi zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 3
Altijd: 36
