Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Reparatie-informatie en -handleidingen voor de CDMA-versie van de vierde generatie iPhone. Model: A1349 / 8, 16 of 32 GB opslagcapaciteit
LED light won't turn off even when powered down!
My iPhone 4 recently got wet and now the LED stays on all the time, even when the phone is turned off. Everything else works fine. Is there a way to fix this without having to replace the whole phone?
Is dit een goede vraag?
Score 37
18 opmerkingen
that recently happened to my phone and I think that we as the people need to realize that the only reason we cannot open and dry out these phones are because Apple wants us totally dependent on them so that they can make more money. Its all about the benjamins.
door Deel
Take a snap with camera with flash on.it works for me
door Deel
wow. I tried everything else I could find and THIS worked.
thank you!!!
door Deel
also going to the settings for auto-lock and switching it to 1 minute will turn it off as well and keep it running normal again, its mainly water damage that seems to cause this
door Deel
thank you, taking the photo with flash on worked! thanks for sharing .
door Deel
13 commentaren meer tonen
Voeg een opmerking toe
29 Antwoorden
Filteren op:
Gekozen oplossing
First, make sure the phone is COMPLETELY dry. I would take off the rear panel, disconnect the battery and leave it alone for several days. If you want, you can put it in a bag of rice to help soak up any moisture.
Try a soft reset of the phone. On your iPhone 4, press and hold both the Sleep/Wake button and the Home button for about ten seconds. The phone should restart.
If that doesn't work, try a restore.
Was dit antwoord nuttig?
Score 6
4 opmerkingen:
How do I do this is my lock button does not work?
door Deel
door Deel
what about a 4s
door Deel
I do every thing and I restor my iPhone for many time but still the flash light is on... What can I do bro
door Deel
Het nuttigste antwoord
It is a bad connection on the 2 prongs to the right of the camera lens. I took the back off and then with a small electrical screwdriver wobbled the connection. The light went dim and by further wobbling the light went off and has stayed off.
Score 8
16 opmerkingen:
Son-of-a-##&&% if this didn't do the trick....thanks a million for your post Michael. I just wiggled the very two prongs you mentioned in your post and the %#*@ light finally went out. The phone is now working perfectly fine after an immersion in H2O!I've been waiting over two weeks with it sitting in a bag full of dried rice to no avail until reading and trying your posted suggestion.....Kudos!
door Deel
Glad to have helped Michael
door Deel
This technique served me well. I can't claim to understand the why and werefore...but thank you!
door Deel
Does the camera flash continue to work after using this technique? The two 'prongs' I see look like surface-mount capacitors to me. I can see how fiddling with those could break the circuit to the flash... never to be closed again.
door Deel
Yes....just jiggle the prongs very gently...not so much as to break them...that is what I had to do and it worked just fine. The light went out and everything works normal including the flash when needed. Hope this helps!
door Deel
11 commentaren meer tonen
my iphone 4"S" ....no backlit ...display working...please help
Update
iphone 4s light will not turn on please help
Score 3
1 Opmerking:
Remove rear cover.. remove the battery.. then remove the shield and make sure lcd and digitizer cables are firmly seated. Theb re connect the battery.
Iphone 5 is the same.
door Deel
Sounds like your camera might have gotten shorted and is defective. Unscrew the two bottom screws and remove the back cover. Then remove the shield and you will have access to the iphone's rear camera. Its not that hard to replace and is available for a good price.
Score 2
3 opmerkingen:
I just replaced the camera and the led is still on, plus the camera shows only black and the shutter does not snap. Any ideas?
door Deel
MY camera actually works. LIKE normal. It's just that stupid flash thing won't.
door Deel
How do you get the back of the phone off?
door Deel
I was just reading some of these.
There are a few of these problems but no one else admitted that the phone got wet and dried out when this started.
Anyway mines been like this for 2 months since it go wet. It was also jailbroken but I really don't think that has anything to do with it.
I got put in the swimming pool with it in my back pocket. No other issues after it dried out.
I just upgraded to 5.0 iOS software upgrade and my light just went out. Hope it stays out but this is the 1st time it turned off.
Score 1
2 opmerkingen:
door Deel
Thanks for the info, once I found auto lock switched it to 1 minute and wella Light went out ....Thanks for a simple fix, ya and I'm gonna get a new 6c,,,,think I better stick with my 5 and learn how to use that....Thanks again....
door Deel
check the coil and backlight ic,but first check with good known display
Score 1
I dropped my iPhone 4 which I am writing this with down the toiliot , was in there for about 4 seconds fully submerged , I quickly retrieved it and dried with a cloth , got cotton ear buds and dried charging terminal and earphone socket on top of phone , phone stayed on all the while , went to car and wedged phone into heater vent on dash and turned heating up for a at least 10 mins alternating between charging point and earphone socket side . Phone playing up big time couldn't enter pin , unlock wouldn't slide if it would unlock then couldn't phone anyone or msg , so I thought phones screwed what the !&^& lets give it a go , opened boot got can of wd40 and straw that comes with it and squirted a little into phone from both ends charging point and earphone socket end . After a while phone started to improve , let me enter pin and get into phone , first few calls I couldn't be heard , then that improved to being heard clearly , only fault is camera light is staying on all time , even when powered off , opened back of phone flipped battery over without disconnecting it wiped access wd40 off and blew dry phone with hair dryer , reassembled but light still on not a major issue if it wasn't draining battery. Oh had nothing else to hand do used wd40 , use at your own risk .
Score 1
1 Opmerking:
how do you take the back off though?
door Deel
My phone was submerged in water for about 10 seconds (dont ask). I put it in a back of rice overnight and took the back off to inspect for residual moisture. It works perfectly except for the led staying on in a low power state. It went off for several weeks and then came back on all of a sudden. Apparently the water cause a short causing this problem. Solution - replace the part. As already noted... it is not difficult to do and there is a wealth of guidance on Youtube. If your phone is dated or battery life is dwindling, its not a bad idea to replace the battery at the same time. Hope this helps.
Score 1
Ite so I ordered a new LCD screed front and back!! While watching a 30 min video on showing me how to replace the screen I replaced the front successfully but whenever I put my battery back in the camera light automatically comes on but is dim how do I fix this
Score 1
I put a black tape over the light. That did fix the problem.
Since I can't see the lights on I'm not going to worry about it. Life is too short to think about apples stupid tricks..
Score 1
1 Opmerking:
smartest comment lol
door Deel
Without opening the back and fingering with the light,how else go I get the light off?
I've tried all the possibles answers mention here but still nothing.
PLEASE HELP
Score 1
Take a picture with the flash. I got the light to turn off on my wife's iPhone 4S this way
3 opmerkingen:
The Perfect answer. That was as easy as it gets! Thank you!!!!
door Deel
Awesome! Im glad that worked for you :)
door Deel
I tried, but its still shining DIMMLY
door Deel
It had happened to me today, the only thing i did was let the phone die and then i held it and hit it with my hand open and the light went off, but then the light turn on, then i hit it with my hand, light goes out and now its staying off. phone dead, LED is dead, now i just have to wait to charge my phone
hi guys im having trouble with mine i dropped it in water today and i have it in rice but when i dropped it i couldn't get it in rice right away because i was not home now the led flash light on the back where my camera is wont go off any suggestions on what i can do im getting married next month and cant afford a whole new phone help me please!?????!!!!!!!!!
after cleaning my phone with a semi wet cloth.....the camera light stays on. What can I do to turn it off? It is driving me crazy.
What I do ??????
I was researching the web on this, trying to find a solution. it fritzed out the day before but somehow corrected itself. but then today the light came on while in my pocket. my leg was getting warm and i noticed the light wouldnt turn off. it killed my battery, and even still the light is on. after intensive research, and me not wanting to spend money on fixing it at the Apple store, Smacking it was a common solution to this. So i smacked it. a few times in the back up in the corner where the light is. nothing happend, light still on. but then i smacked once in the front opposite of where the light is, and it worked the light turned off.
4 opmerkingen:
WOW! smacking the back a few times and then the front actually worked. At least for now...after a absolutely abusing the poor thing, we will BOTH have trust issues for awhile
door Deel
I'm afraid I'll smack too hard. You smack exactly where the light is?
door Deel
Jeffychrn, please see and apply the method mentioned my Michael that he posted on November 3, 2014. If you've dried out the phone completely and the light is still coming on it more than likely that the two prongs next to the camera lens need to be wiggled to fix the bad connection. It worked for me just as it did for Michael. Perhaps this is the reason hitting around that area appears to help some people. But you might cause more harm than intended by hitting your phone too hard and causing more issues than the one you currently have. Hope this helps you too!
door Deel
I cannot find these two prongs everyone speaks of. I removed the back. I have looked to the right of the camera. No prongs that I can see. Of course I am absolutely blinded by the light shining n my eyes and it burns my finger when I try to mute it.
door Deel
My light randomly turned on an hour ago. Power off, nada. Soft reset nada. I tapped the phones edge on side of table as if to drop it 6". It's fine now, leads me to believe its a short.
my iphone 4 has been having the light prob too I went on other websites they said they slammed it a couple times so I tried slamming it a couple times and still the light is still there it would be embarrassing to take my phone to school or public I already upgraded my phone do u have anymore solutions
slam your phone against a wall! it really works
My boyfriends son spilt some soda on his phone. I immediately turned the phone off and let it dry for over 24 hours. I should have put it in rice and let it dry for 48 hours as I've done before when i dropped my iphone in the toilet. Anyway, when we turned his phone on, the camera led light came on and wouldn't turn off. So, I downloaded a flashlight app from the app store, turned the flashlight on and then off again. It worked and the light stayed off. Made the mistake of letting it die and when we powered it back on, the light came back on and the app trick isn't working now. Leads me to believe we shorted something out, the battery life is awful and the phone gets hot in his pocket. I would suggest upgrading your insurance plan to one that covers water damage and then filing a claim through your carrier and sending it back.
take a picture with the flash. i got the light to turn off on my wife's iphone 4s this way
2 opmerkingen:
I tried this a few times with the flash turned "on". It didn't work. Then, I turned the flash to "auto", covered the camera with my hand to make it dark and voila, it flashed and shut off after. Now, it's sitting in rice overnight. I went to the Apple store to ask them to open it so could dry out and they refused to do it. Their only solution was to buy a new phone.
I am now going to order a pentalobe screwdriver from Amazon so I can actually take the back off myself as needed.
door Deel
Update. The light came back on when it was powered off. Plan to get the screwdriver and take the back off to dry it out. All this because of a few drops of water on my iPhone from melting ice.
door Deel
I had this happen with my 4S after it fell in the bathtub and got wet. I retrieved it within less than 3 seconds, wrapped it in a towel and dried it off. In a panic I attempted to blow out any errant moisture with a hairdryer (no, no…). I also repeatedly powered the phone off and on (another no, no). The phone had remained on throughout the soaking and initial drying process. The only thing I noticed was some moisture under the glass in front of the rear camera lens. I kept a warm dryer on it until the moisture evaporated.
At some point I turned on the camera to test it and the LED remained lit. Even after powering the unit down, it remained lit. At first it was fully lit, and then over time it began to fade and remained lit dimly. Testing the flash feature, I could still get it to flash and using a Flashlight App I could also get it to strobe, but never turn off completely. All other features of the phone functioned fine. For what it's worth, upon inspection, only the headphone jack moisture exterior sensor was tripped, the power and (after removing the back plate) interior sensors were not red. I checked the camera connections, uninstalling the camera and putting it back in. Still the LED remained lit.
From researching online, I concluded that moisture had gotten into the camera and LED housing and there was a short keeping the LED lit. I ordered a new camera, disconnected the battery, installed the new camera and all appears to be fine!
What I'd do differently next time (had I had the tools): Immediately power down the phone after the first pat down with a towel. Open the back case and inspect the interior for moisture. I think heating the phone and blowing it out so much probably forced water deeper into the phone and ultimately compromised the LED. Had I just let it be and carefully dried it with the case open, I might have avoided shorting it out. A can of compressed air probably would have done the trick. I don't think much water had actually gotten inside, and it was just all the heat and evaporated water that was my real enemy.
Hope this helps someone.
Had the iphone in a ziplock while riding a wave-runner and it got a little wet. The camera light will not turn off but the rest of the phone worked. Tried all the suggestions here but none of them worked and I was ready to bring it to the Apple store to replace the camera module. However, after keeping the phone in a combination of rice and oats for 24 hours, the light went off. I guess the inside just needed to dry. Glad I was patient. Good luck!
Two months ago my 4 got wet. I put it in a bag of rice for about 2 weeks (it didn't work, i kept checking). Finally, after the 2 weeks, the phone finally turned on, but the flashlight came on and wouldn't turn off. I powered down, did everything and nothing worked. Finally, on it's own, it turned off.........til about 3 days ago. It's back. I tried powering down, using the flashlight, holding the sleep/home buttons, taking a picture with the flash but nothing. It seems like this is an Apple defect. Does anybody have any other suggestions as to how to possibly turn it off? Thanks!
oh.. i had the same problem recently... but i fixed it myself..!
please scratch our brain and think that you have not installed any antivirus software on your i phone. if you have then please make sure its not been deleted or out of date.
please configure that antivirus and update the necessary. your problem will be solved.....anyway mine did!!!
hope that will help many...!!!!
Using drier to heat on the position of camera lens of the iphone, it gets dry if its defect by watery. After 2 mins take a snap on the camera with flash light on. It works!
You take the back off and wiggle the prongs to the right
Voeg je antwoord toe
Jonathan Lebrun zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 21
Afgelopen 30 dagen: 63
Altijd: 372,777
