Ga door naar hoofdinhoud
Sony’s 20.1 megapixel camera designed to capture still images and video recording up to 720 pixels.
15 Vragen Bekijk alle
Why is my lens making noises like cracking when opening and closing?
I accidentally dropped my camera about 2 days ago, and ever since, it wont open all the way to take a picture. It says to power it off, then whe turned on, it makes cracking noises.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
@yoitsnickb
by the sound of this, it is possible that the lens is of track. Try some of the tricks from here Most likely you will have to repalces the lens since individual repair parts are most often not available. You can use these guides Sony Cyber-Shot DSC-W830 Repair or the attached disassembly manual to work on your camera DSC-W830-Disassembly.pdf
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Nickolas Banks zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 19
Altijd: 247
