Weber Grill Pressure Regulator Diagnosis / Replacement
Trying to figure out what is wrong with a older model propane grill made by weber. someone cranked on the plastic collar , attached to the pressure regulator with a wrench . i dunno why. I suspect the compression fitting i guess for the pressure regulator will not work correctly now , maybe cracked from using a wrench for no reason.
grill was working perfect before this now no smell of propane , appears to have no gas flow . Part of the problem is i dunno / remember what the model is . I have attached a few more pics below.
if i am correct , i just need a new pressure regulator , so if anyone has any ideas on what a “good” compatible model or just weber OEM one i could buy it would be appreciated.
Is dit een goede vraag?
