Ga door naar hoofdinhoud
The 2016 version of the Samsung Galaxy A3 budget smartphone (model number: A310F).
20 Vragen Bekijk alle
phone wont charge with screws all the way tightened
hi all
I’m having a wierd problem with my galaxy a5. i dropped my phone from a 3rd floor balcony which landed on grass and soft mud but after i picked it up it still worked but wouldnt charge anymore. after some tinkering i discovered that if i slightly loosen all the screws in the phone it charges but as soon as i tighten the screw its stops charging again
does anyone whats casuing that and how to fix it?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
The only thing I can think of is that the soldering for the charging socket on the daughterboard has gotten loose after drop meaning it would require soldering. But if it’s working just by loosening the screws a bit, you might be able to just leave it like that and use it for now.
You can take it to a phone repair shop to get them to fix it for you, luckily this model does not require prying up the screen to get inside the phone.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Gary zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 70
