Ga door naar hoofdinhoud
The PlayStation 3 (or commonly known as the PS3) is the third home computer entertainment system produced by Sony Computer Entertainment, and the successor to the PlayStation 2. It was released November 11, 2006
781 Vragen Bekijk alle
Why my PS3 makes noises and then turns off after 5-10 secs?
Hi. I’ve just bought a PS3 Fat and it turned out to be problematic. When I turn it on it is working but after 5-10 secs it starts making noises and then it turns off.
Here’s a video:
https://www.youtube.com/watch?v=7WruPnmu...
What could be the problem? I tried to diassemble it today. I removed the blu-ray, the psu and the wireless card but I couldn’t get the hard drive out. There wasn’t dust over the hard drive. I will try to find a screwdriver for the hdd tray tomorrow. Is the problem dust or there’s something else wrong with it?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
The noise I heard in the video was the fan going to full speed. This was followed quickly by a shutdown. It suggests that the machine is overheating. The machine will first increase the fan speed in an attempt to cool down the CPU. If this fails to work, the system will shutdown to prevent damage to the CPU. I would open up the unit and replace the heat compound for the CPU. The existing compound is probably dried out and not working properly. Replace this first. Also, clean out any dust inside the unit and clean the fan blades. Re-assemble and try again.
Post here the results of the above.
Dan
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Jack zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 14
Altijd: 515
