Ga door naar hoofdinhoud
Alles over de Fujifilm X20.
Refuses to turn on
For some reason my X20 will not simply turn on. I have charged the battery still nothing Help please
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Have you tried pressing the play button to turn it on?
Was dit antwoord nuttig?
1 Opmerking:
Hello Andrew 6, I have same problem and when I press play button it starts playing the photos but the switch is of. If I switch on it will not do anything, could it be this fuse? Thanks in advance
door
I’ve had exactly the same problem on my X20. I followed the disassembly guide and traced the fault to a blown fuse on the main board, a tiny SMD fuse in 0603 package. I believe this is rated at 2.5A. I’m going to replace it and if it works I will add a replacement guide. Hopefully there are no follow-up faults.
Update (05/14/2020)
I’ve replaced the fuse on the PCB and reassembled the camera - it is working absolutely fine now! I've added steps to the disassembly guide to show where the fuse is located.
1 Opmerking:
Where is this fuse located? Is thid fuse easily available?
door
Voeg je antwoord toe
Angus zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 36
Altijd: 1,357
