Ga door naar hoofdinhoud
Ondersteuning voor golfkarren op gas en elektrisch, soms golfkarretjes of 'club cars' genoemd naar het merk Club Car Golf Cart.
Forward/reverse lever are backwards
Hi gang, I have a 2001 Club Car DS 4 stroke gas engine. Problem is small but it irks me that I cant seem to find the solution. When the cart is in the forward position it goes backwards and vice versa..,when its in the reverse position it goes forward. A little help please...chances are this is a simple fix but I guess I’m having a brain fart and cant figure it out.
Is dit een goede vraag?
Score 1
1 Opmerking
That’s great looking into it now, I don’t see those studs but will explore a bit more.
Thanks a lot for your response, will keep you posted.
door
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Gekozen oplossing
Look at the motor. On one end of the motor (the side closest to the gearbox) the studs will be labeled S1 and S2 (for a Series cart) or F1 and F2 (for a sepex cart). Take those two cables off and swap them and your problem should be rectified
Was dit antwoord nuttig?
Score 2
6 opmerkingen:
Simple, brilliant answer.
door
I’m not sure what a sepex cart is...you do realize that I’m talking about a gas engine right?
door
No luck finding the two studs to swap over the cables, just dont see it. Sorry....thanks for trying though, appreciate it.
door
1 commentaar meer tonen
The problem is someone has changed the motor. Earlier cc engines ran counter clock wise and the newer ones run clockwise hence your shifter works backwards
Score 1
2 opmerkingen:
So does this reverse the gearing as well? Reverse gears should be lower than forward gears correct?
door
This seems to be the correct answer as my cart is the same way.
door
Voeg je antwoord toe
Den Gauthier zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 30
Altijd: 2,546
