Batteries are already the weakest link in the aftermarket industry. With the recent admission by Apple that they were throttling devices when the battery was weak, there has been a huge global demand for replacement batteries.
I suspect that that with this excessive demand, lower quality batteries are making their way through the supply chain where they otherwise wouldn't. iFixit has a great reputation when it comes to replacement batteries but shipping them can be an issue. They may charge more but you are paying for a vendor that does thorough quality control of their parts and really stands behind them if you ever have any issues.
When you see stuff on Amazon or eBay, you are generally seeing the bottom of the barrel parts. These are the parts that pretty much every other major vendor has refused. Vendors do random checks of available lots and if the defect rate is higher than they'd like to see, they will pass on the lot. It doesn't mean they are all bad though and it doesn't mean there aren't any good parts in those lots.
So yes, you could save money by buying on Amazon. If you have a tight budget or don't want to spend too much on an old phone, by all means order those parts. But there is a very real probability that you will receive a crap part and if you do, you may have a hard time getting an exchange or refund.
1 Opmerking
I replaced the battery for my Braun Series 7 Shaver and it was identical to the original. I followed Ifixit install guide and charged it 15 hours before use. It holds a charge exactly like the original when new. Perfect. I also did a Philips Sonicare toothbrush and had the same results. It would not last 2-3 brushes but now will go for weeks. Bravo
door Gerald R Arnold II
