Ga door naar hoofdinhoud
Een e-sigaret is een herbruikbaar alternatief voor traditioneel roken.
121 Vragen Bekijk alle
G Priv Baby Luxe Bricked, need 1.0.1 Firmware
Similar to a guy I saw on here with a T-Priv 3, I bricked my mod after doing a firmware update wrong. I require the stock firmware for a G Priv Baby Luxe in order to get my baby working again, any help would be amazing.
Is dit een goede vraag?
Score 6
3 opmerkingen
I have the same issue and in search for the stock firmware for this mod.
door
Hi. I found a great place where I can get all the vaping products I need and I thought I should share it with everyone.
It’s called Vaperite. Check them out https://buff.ly/3P5BF9b
door
Gwam stands for Global Wholesale and Marketing and it is an online store that bridges the gap between you and products from all around the world.
The exclusive distributor for our esteemed products <a href="https://gwam.pk/product-tag/wape/">Aroma King</a>,<a href="https://gwam.pk/product-category/pods/sm...> Smok</a>, <a href="https://gwam.pk/product-category/pods/vo...>Voopoo</a>, and <a href="https://gwam.pk/product-tag/caliburn-pri...>Caliburn</a> is Global Wholesale and Marketing (Private) Limited. It is renowned for providing the best import services in recent years and brings all varieties of pods, vapes, and energy drinks to your table in high-quality.
door
Voeg een opmerking toe
10 Antwoorden
Het nuttigste antwoord
Thanks to Danillo for solving this problem.
To revert your currently brick mod back to the stock firmware you need to download the Nuvoton firmware update software from Smok’s website and the original firmware bin file.
Remove the battery from your Smok device
Open Nuvoton NuMicro ISP Programming Tool 2.00
Hold the fire button on your Smok device and connect to you computer using the micro-usb cable (you have to hold the fire button during the entire process)
Once device is connected to the computer you should get a device connected notification on your computer. On the Nuvoton window click Continue and then Connect on the next screen
Click on APROM and select the stock firmware .bin file you have downloaded and ☑ the following
Click Start and your device should be fixed
Was dit antwoord nuttig?
Score 3
1 Opmerking:
Thanks a lot..
door
I have the same issue, I think I installed a G-Priv II 1.0.5 firmware instead and now it won't boot. is there a way to format it back to 1.0.1?
Score 1
1 Opmerking:
Do you fix your proplem i had de same issue
door
Does someone has a solution for this? Where to download the original firmware?
Score 1
I made the same mistake. I have emailed smoktech support. Has anyone still found any solution?
Score 1
1 Opmerking:
Apparently smok after sales service told me to install the firmware! Where the Effin Eff is the firmware? Bunch of idiots!
door
hola he cometido el mismo error que necesito la solución wtf
Score 1
1 Opmerking:
Hallo habe die original Firmware für die G-Priv Baby! Kann sie per E-Mail zukommen lassen!
door
Score 1
15 opmerkingen:
please send to me edwinval.reyes@gmail.com
door
can you email it to me too ?? jimilvineyard96@hotmail.com
door
please send to me, please : totti953@hotmail.com
door
please sent it to me yunghoe23@gmail.com
door
I need it please! eduvicma@hotmail.com
door
10 commentaren meer tonen
yea, and dont forget to send it to me pls!!!!!!!!!!!!!!
yveso45@gmail.com
Score 1
1 Opmerking:
Can you plz send to me too...
Dventura517@gmail.com
door
May I have the original firmware sent to me as well please. for the gprive baby lux email to forever4lala@gmail.com
1 Opmerking:
do you have firmware E-PRIV
door
arslanfurkan999@gmail.com
Hi, pls send for me too
barthagery@gmail.com
Voeg je antwoord toe
knroo6 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 18
Altijd: 5,782
