Ga door naar hoofdinhoud
A gaming headset that is compatible with the Xbox One.
8 Vragen Bekijk alle
How to fix water in microphone
So I was playing Xbox with my friends and just as I was talking to them I decided to drink some Pepsi, just then I started choking and spluttered some Pepsi inside the mic and it just got worse from there. What should I do?
It got inside the little tiny hole and when I’m talking to my friends on Xbox they can’t hear me at all
Is dit een goede vraag?
Score 10
3 opmerkingen
I have a elecder i39 and i got water in the little hole and it wont work at all. I have to use the chat for zoom.My mic is attched to the cord and its really annoying.HELP ME PLS!
door
i cant get the mic replaced bc it is part of the cord
door
same i thought a mic would survive coke then it started to buzz alot with a voice changer
door
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
try letting mic dry i suggest air dry or blowing into the hole it help me
Was dit antwoord nuttig?
Score 3
Hi,
Your best option is to replace the microphone boom as most probably the microphone will be damaged beyond repair, even if you could get to it to repair it without damaging it.
Score 1
2 opmerkingen:
What if the mic is attatched to the headset?
door
mine is and you would have to cut the cord
door
you can try to hairdry it or blow it out that might help
Score 1
Voeg je antwoord toe
ruairi.moran zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 10
Afgelopen 7 dagen: 47
Afgelopen 30 dagen: 200
Altijd: 22,499
