Ga door naar hoofdinhoud
In augustus 2000 werd de negende generatie Corolla geïntroduceerd in Japan, met een scherper design en meer technologie om de modelnaam de 21e eeuw in te loodsen.
AC randomly turning off
So I have a 2007 Corolla. Sometimes when I start the car the AC won't turn on. None of the speeds work. Then randomly while driving, it will kick in and work for a while.
The first time it happened, it was only for a short time, and didn't happen again for a while, but now the 'outages' are getting a little closer together. I don't know if there seems to be a short in the wiring or something? Any help would be appreciated.
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
This sounds like a bad ground . Finding the end of the ground wire can be a task . It is often easiest to just run a jumper off the ground wire at the blower and make a new ground on the firewall with a self taping screw . Hope this helps
Was dit antwoord nuttig?
Score 3
I have the same problem,
I have three cars for me, my wife and my son.
I used to take them to a mechanic, and he always created more problems than he fixed.
Suddenly, all three cars experience the same issue: the AC works intermittently and stops working at times. The Corol car heats up if I turn the AC on, but the coolant fluid is normal
Where can I find the ground wire, or where should I begin my search?
Voeg je antwoord toe
Andrew Fisher zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 17
Altijd: 671
