Ga door naar hoofdinhoud
Model A1419 / EMC 3070 / medio 2017 / 3,4, 3,5 of 3,8 GHz Core i5 of 4,2 GHz Core i7 Kaby Lake-processor (ID iMac18,3) / Retina 5K-display. Raadpleeg de oudere handleidingen van de iMac Intel 27" Retina 5K-display (eind 2014 & 2015), aangezien het systeem sterk overeenkomt.
CPU Upgrade to 8th Gen Intel
Hello Guys!
Last year I bought a base model iMac 5K and it was working fine for me but my work has intensify and I would like to upgrade the CPU to an i7 and the HDD to and SSD .
My question is: Now that Apple lunched the Eight Gen CPU's in the new Macbook Pro. Can I opt for the 8700K(or any variant of it) instead of the 7700K?
Is dit een goede vraag?
Score 3
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
Sorry not an option in your system the rest of the systems logic would need to be swapped out as well (which is not practical) your system is based on Kaby Lake the new 8th gen is using Coffee Lake architecture while similar it’s not drop in compatible.
Was dit antwoord nuttig?
Score 2
hi Alex Castro your imac only upgare to high cpu but only same life and socket
This is possible,It has been done on motherboards from third party vendors, apples logic is no different, What is needed is a patch for the bootloader, or a spoof in the efi and the compatibility fix added to it that was done with z170 motherboards.Whoever does it first will get a ton of rep.For now though if you can get a 7700k, you wont be disappointing, And I wouldn’t hold your breath on anyone in the mac community putting as much trial & error and time into this.(Just saw that its quite a few months old, didnt mean to revive the dead thread).I also swapped in a 7700k from an i5, tricky but rewarding.
1 Opmerking:
Yes its easy on a Windows PC, Mac's are a very different beast! Its just not that easy. Unless you've got the skills to dig deep into the firmware its just not possible!
door
Voeg je antwoord toe
Alex Castro zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 22
Altijd: 3,797
