Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Tablet van 0,622 kg (1,4 lb) met een scherm van 10,8 inch en een uitklapbare standaard met 3 standen, op 5 mei 2015 uitgebracht door Microsoft. Modelnummer: 1645.
I broke the display and need to replace it.
I have a Microsoft Surface Model 1645.
What is the proper display and do you offer one?
If so, what is your part no. and what is the cost?
The old one has a part no. LTL 108CL01-001.
I'm confused, is this a 10.8 or 12 inch display? It measures 12 inches diagonally, however all the literature says its 10.8 inches.
The part no. on it suggests it's 10.8 inches.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Filteren op:
Gekozen oplossing
Hi @xxjimxx ,
Are you measuring the diagonal length of just the screen area itself or the total diagonal length of the tablet?
According to the specs for a Microsoft Surface 3 (1645) its’ total dimensions are 10.52" x 7.36" which gives an overall diagonal length of 12.8"
I agree, searching online seems to indicate some confusion by suppliers between a Surface 3 and a Surface Pro 3 (1631) which does have a larger screen and also a different native resolution.
If the model number is 1645 I’d go with the 10.8” screen as that is what the specifications state.
Here’s a link to the ifixit Microsoft Surface 3 Display vervangen guide, which may be of some help.
Ifixit does carry some parts for Surface 3 tablets.
Surface 3 Screen
Replace a front glass digitizer screen compatible with the Microsoft Surface 3 model laptop. Features a 10.8 inch 1920 x 1280 pixel LCD Display. Afbeelding
Product
Surface 3 Screen
$179.99
Was dit antwoord nuttig?
Score 3
Voeg je antwoord toe
Jim Neely zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 23
Altijd: 428
