Ga door naar hoofdinhoud
Repair guides for the Kenmore 80 Series of washing machines, manufactured by Kenmore.
20 Vragen Bekijk alle
Timer is moving, wont aggitate
Kenmore 80 model.. Since i havent over loaded it, just keep it busy! I put in a small load it filled but wont aggitate. After reading the previous question, how do i check the lid switch? Also, the timer knob seems to be moving so i assume its not the timer?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Cause 1
Agitator Repair Kit
If the washer won't agitate, replacing the agitator repair kit may solve the problem. The kit contains the agitator components that are most likely to wear out and/or fail. If any of the parts are worn out, stripped, or damaged, replace the kit.
Cause 2
Drive Block or Bell
The drive block connects the washer transmission to the agitator. If the drive block is worn out, the transmission shaft will still move back and forth, but the agitator will only move slightly or will not move at all. Inspect the drive block for damage. If the drive block is worn out, stripped, or damaged, replace it.
Cause 3
Motor Coupling
The motor coupling connects the motor to the washer transmission. If the washer is overloaded, the motor coupling will fail in order to protect both the motor and transmission. The motor coupling can also fail due to normal wear. Inspect the motor coupling to determine if it is broken. If the motor coupling is broken, replace it.
Was dit antwoord nuttig?
Score 3
Voeg je antwoord toe
c_page_fl zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 269
