Ga door naar hoofdinhoud
The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
1185 Vragen Bekijk alle
How do I fix the built in keyboard and trackpad from disconnecting?
As of two weeks ago my MacBook Pro stopped recognising my trackpad and keyboard. The issues started only after I did a software update. I managed to login using a bluetooth keyboard in order to reset the computer and revert to the version I was originally running.
It took a day to do this, and it seemed to work fine after that. However, the issue has resurfaced.
Depending on the angle I hold my MacBook the keyboard will work or not work. Is this a problem anyone else has encountered? Does it sound like a hardware problem? What should I do stop my keyboard and trackpad from disconnecting?
MacBook Pro (Retina, 13-inch, Early 2015)
2.7 GHz Intel Core i5
8 GB 1867 MHz DDR3
Intel Iris Graphics 6100 1536 MB
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
The keyboard & trackpad share the same cable connect to the logic board.
There are two possiblities: The battery is pressing on the cable as it’s failing and the cable it’s self got damaged from a bang on the bottom cover.
I would check the battery using CoconutBattery to see how many cycles it has (if you’re over 700 it’s time for a new battery).
Here’s the cable 821-00184-A trackpad cable for 13" A1502 2015 Retina Macbook Pro
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Thank you Ben. That sounds like the issue. I just checked the cycles. If the problem persists, it may be that the trackpad cable needs replacing.
door
Voeg je antwoord toe
Daniel Brasher zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 119
