Ga door naar hoofdinhoud
Model A1347. Released on October 23, 2012. Core i5 or Core i7 Processor. Apple Fusion Drive.
Mac Mini dead. Fan just keeps quarter spinning ‘pulsing’
Hi. Just wondering if anyone knew what might be the issue here. PSU is fine so it looks to be a logic board issue, but I’m not sure if it’s something than could be fixed.
When I attach the power cord, the fan does a quick spin then stops, then a quick spin again, then stops, and it just keeps doing this. This is without touching the power button. It’s looks like something is failing even before it can be in a state to be turned on.
There are some places that do logic board repairs, but maybe someone has an idea what the issue may be, as I’m a little concerned leaving my Mac mini with someone for several days with 2 drives full of all my personal stuff.
It’s a Mac Mini Late 2012 2.6GHz i7 (A1347)
Thank you,
Keith
Update (07/14/2018)
Someone had a look, but can’t do repairs at a logic board level. Initial diagnosis, “Sadly it is the logic board and not the power supply. I don’t have a schematic for the board so can’t confirm the issue but one-wire communication for power on is working but the processor is not providing the start-up logic.”
Is dit een goede vraag?
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
Took it to Apple Genius Bar
they said it needs a new logic board = £337
as the MacMini is less than 6 years old (5years 10months) I asked it they would fix it for free, under consumer law (worth a try!)
Genius had a quick chat with store manager. They approved and replaced the logic board for free.
I was expecting a bit of a fight, but there you go. Well done Apple :-)
Was dit antwoord nuttig?
Score 1
Het nuttigste antwoord
While IFIXIT appears to be out of stock, here’s the needed logic board: Mac mini A1347 (Late 2012) 2.5 GHz Logic Board
Replace a 2.5 GHz Core i5 logic board (motherboard) compatible with the Mac mini A1347 Late 2012 model. Fix processing issues like unexpected shutdowns, reboots or water damage. Afbeelding
Product
$299.99
Score 1
3 opmerkingen:
Thanks Dan.
So it sounds like I need a new logic board, rather than someone being able to repair this ?
Thanks for the link. Mine is the upgraded i7 CPU however.
door
Someone could repair it, but they would charge around the same to desolder a component and solder a replacement component. I suggest purchasing a new logic board and keeping the non-functioning logic board in an anti-static bag if you ever decide to have a professional fix it for you.
It might not even be worth it if a lot of components on the logic board are dead or not working correctly.
door
I agree with Macario, it tends too be about the same cost and this is quicker.
door
Thanks everyone.
I just can’t seem to find the logic board with the same i7 CPU that I have.
Voeg je antwoord toe
keith zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 4
Altijd: 1,305
