Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Vragen Bekijk alle
Why doesnt my wifi get connected?
Recently my wifi has auto forgotten the wifi and when I try to connect the wifi to the phone again it doesn't work. An error message pops up saying "enable to connect". What should I do? Please help !!
Is dit een goede vraag?
2 opmerkingen
Does it work on other wifi ?
door
Can you enable wifi or the setting itself is greyed out ?
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
It seems like your wifi antenna in the iPhone isn’t working properly. Try a factory reset, but back up your information first. If that does not work you’ll need to replace the wifi antenna. It’s not a hard process. the part can be found here: https://www.fixez.com/store/iphone/iphon...
The tutorial can be found here: iPhone 6 Wi-Fi Antenna Replacement
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
unicorn sparkle zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 29
