My S Pen broke off, half still inside, how can it be removed?
Help get SPen out of phone?
Is dit een goede vraag?
Smack the bottom of your phone or lightly hit it on a table, it should come right out when you shake it!
Was dit antwoord nuttig?
This worked for me, thanks.
purrrrfect solution , thank you
Worked for me too thanks!!
This worked thanks alot. ?
Worked great for me. Thanks!
Tweezers? Here is a video of someone getting one out:
My S pen broke outside phone and i put it back in there Not thinking. The pen came out but part of the plastic encasing remained inside. How can I get this to come out?
Mine was stuck way inside the phone. I used a drill with a tiny drill bit and drilled into the hole in the stuck s pen. All you have to do is simply pull it out. It ruins the s pen, but you can get a replacement on Amazon
you can use a phillips screw driver and insert it inside. it worked best for me to take out the broken s pen inside.
Yay! the screwdriver is the only thing that worked for me! thank you so so much!
I used the old-type iron twist serving to prepare a hole in the wood plate for screwing-in the screw. I think this is the best solution!
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 35
Afgelopen 30 dagen: 175
Altijd: 21,809
2 opmerkingen
I used a lock picking tool it had a hook on It tried for 30 min then I prayed put it back in felt it move and out it came .
door Beth ann Poole
Grateful it worked
door Nintai Neville Nfor JR
