Ga door naar hoofdinhoud
How to fix home button
I know the finger print scanner will never work but I am unsure if the button will not work. If I get a replacement home button and install it would I be able to use it as a normal home button without Touch ID?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
No-- a replacement home button for iPhone 7 will not be recognized by the device and will not work either as a home button or as a fingerprint sensor. You might as well just put a rhinestone there.
Was dit antwoord nuttig?
Score 1
Het nuttigste antwoord
Replacement Home Buttons for the iPhone 7 are for cosmetic purposes only. If you still have the original button, the "click" or return function can be repaired but not the TouchID.
Score 2
2 opmerkingen:
How can the click be fixed?
door
Go to Apple and get a new screen that will come with a new home button, fcam assembly etc. This is the only way
door
Voeg je antwoord toe
Haris zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 2,918
