Ga door naar hoofdinhoud
The Nintendo 2DS is a handheld gaming device developed as an entry level version of the Nintendo 3DS with nearly identical hardware, but without the 3D upper screen function.
20 Vragen Bekijk alle
Stripped screw on 2DS battery cover
I recently got a 2DS off ebay, and one of the screws on the battery cover (The left one) is stripped to the point of being basically round. Is there any way to remove it without damaging the rest of the system? I've already tried the rubber band method, too.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
I ended up just drilling the screw to remove it.
Was dit antwoord nuttig?
Het nuttigste antwoord
You do know that this is a captured screw?
I would use a demerol tool and cut a notch straight across it so you can use a flathead to get it out.
Nintendo 2DS Battery Replacement
Score 2
Voeg je antwoord toe
Jonas Clermont zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 6
Altijd: 565
