Ga door naar hoofdinhoud
Launched on November 2014, the HP Stream 13 is a thin unibody Windows® laptop priced to compete with Chromebooks and the entry level MacBook Air.
12 Vragen Bekijk alle
Help ASAP! Hard Drive Upgrade Via WifiPort!
Question and I need help!
I have an HP Stream and the hard drive is only 32gb and soldered via EMMC and need to upgrade it! I have the HP Stream 14 series this year I believe!
Now, I saw an existing forum regarding this laptop here: HP Stream 13 Disassembly for Upgrading the PCIe mini SSD
However, I do not get answers and I believe the user that said using MSata hard drives will work won't answer anymore! I am wondering if this has been confirmed working and if anyone has tried it and was successful! I have the wifi card here I took out: https://ibb.co/hANX98 and not sure what ssd to buy that will fit the existing port to try out!
Any assistance would greatly be appreciated!
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Your WiFi board uses a PCI Express Mini Card interface. So it’s conceivable a a short mSATA board would physically fit. The only risk is if the system would recognize it.
mSATA SSD (mSATA solid-state drive)
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Daniel Ringuette zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 8
Altijd: 467
