Ga door naar hoofdinhoud
The Astro A40 TR Headset is an audio device released in August 2015, identified by model number 3AS48-XOU9N-601
18 Vragen Bekijk alle
Headsets broken, only works when cable is pushed in hard.
Headset gets no volume or input from the controller or something because it only works when I push the cable into the headset extra hard and hold it there. Not sure if this is common but thats how Id describe it.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Hello,
It sounds like some thin wire connecting to the speakers have broken. Jamming the cable in probably helps the broken ends connect.
You can take a look at this guide here to see what it looks like inside. Repair may require some delicate soldering.
Was dit antwoord nuttig?
Voeg je antwoord toe
shortstackgc123 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 24
Altijd: 1,959
