Ga door naar hoofdinhoud
Is there any way to remove scratches from the screen of a Moto Z2 For?
My Moto Z2 Force screen is made of plastic and therefore I was told that this phone would not be a to break but lately I have noticed these little scratches on my phone which is quite disturbing so if you could help some how I'd appreciate it. -Thank you.
Is dit een goede vraag?
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
Hi!
Unfortunately, the screens of the Moto Z2 Force does scratch easier than that of the original Z Force and you cannot get a free replacement from Motorola like you could for the Z. But you can buy a new upper layer from them and I believe they also install it for you. Have a look here: https://www.motorola.com/us/products/mot...
As for removing the scratces yourself... I do not think that is possible, all you can do is preventing any more scratces by applying a screen protector (cheap, plastic ones are just fine, you wouldn't need the fancy, thick glass ones since the screen is already shatterproof) like this one.
Was dit antwoord nuttig?
Score 1
http://homeguides.sfgate.com/remove-scra...
Score 1
I do believe you could use cerium oxide. It's used for polishing watch glass that's not crystal glass. Hesalite glass was common on watches and was easily polished with toothpaste! I guess the z has some kind of acrylic glass and then cerium will work fine. Be careful! It's toxic and you can easily make the screen wavy if you rub too much.
Voeg je antwoord toe
Aracely zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 7
Altijd: 1,284
