Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
2690 Vragen Bekijk alle
this accessory may not be supported
When i plug my phone in, it might charge for a little while but then i get a notification saying “this accessory may not be supported” and then stops charging. super annoying, especially if i am away from my phone and can’t unplug the charger and re plug it in for it to start charging again. do i need to replace my battery? how do you fix this.
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Calvin,
The message you are recieving means that either you are not using a genuine apple charging cable, or that the cable itself is at fault. Your best course of action is to buy a new cable.
I hope this helps,
Charlie B
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
calvin robison zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 3,943
