Ga door naar hoofdinhoud
De 2015-versie van de Samsung Galaxy A3 budget-smartphone.
galaxy alpha not powered on
not power on and not charging
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi,
Have you tried a different compatible charger, different charger cable or even connecting it to a computer to see if it charges at all?
Use a magnifying glass and a strong light to check the phone’s USB charge port. Check that all the pins are there and that they’re all straight and parallel with each other. Also check that there is no lint etc. trapped in the enclosure.
If there is lint trapped in there, DO NOT use a pin etc to try and get it out, as you may damage the USB pin connectors or even cause damage to the internal components. Use a vacuum cleaner to try and suck out any debris. If it won’t come out, use a wooden toothpick to gently prise it out.
If the port seems OK try the following:
Plug the charge cord into the phone only. Do not plug the other end of the cable into anything. Whilst firmly holding the phone in one hand, grasp the plug of the cable and gently stress very gently try to move it from side to side and up and down to check if there is any movement in the USB port.
If movement is discernible (indicating that the USB port is possibly loose from the systemboard) or even there is no movement, the phone will have to be opened and the problem further investigated.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
anwarh_jamali zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 356
