Ga door naar hoofdinhoud
4-inch iPhone released in March 2016 with similar hardware specifications to the 6S. Available in Silver, Space Grey, Gold, or Rose Gold with 16/32/64/128 GB storage options. Model: A1662 and A1723
1049 Vragen Bekijk alle
Dim screen after screen replacement - iPhone SE
Hi! I am new here and i don't have experience whn it comes to hardware replacement.
So, i recently replaced my iPhone SE screen with an OEM one and after finishing up i noticed that the screen brightness is lower than normal (although in settings it's at 100%). I know it isn't that big of an issue but i would like to fix it anyway.
Here are some pictures where I compared my iPhone with another one that is working normally: https://imgur.com/a/zZC1uIO
Sorry for the bad res. I had nothing else to take the pictures with :S
Is dit een goede vraag?
3 opmerkingen:
Where did you order the replacement screen from?
door
@mikeyd123 I am from Romania and i bought it from an online shop here. I just want to know if it s something easy fixable or it requires some sort of soldering, in wich case i'll take my phone to a service.
door
Sorry I took a while to get back to you. This is easily fixable. Just order a new replacement screen, the one you have now is most likely defective.
door
Voeg een opmerking toe
2 Antwoorden
Order another part but from a different site and replace it again.
best part places I know of:
https://www.fixez.com/store/iphone/iphon...
[gekoppeld product ontbreekt of is uitgeschakeld: IF124-049]
Was dit antwoord nuttig?
2 opmerkingen:
@touretteskey Nah. I want to know if i can fix it as it is. I don't want ti buy a new one as I can use it like this anyway.
door
I understand, but to be completely honest with you, the LCD is not working properly and a new part is needed. This cannot be fixed as is.
door
Carol,
I suspect you did not get an OEM quality screen. I've seen low quality screens that are dim, off-color or have odd lines running through them when first replaced.
I recommend purchasing a replacement from iFixit: their screens are some of the best I've purchased.
iFixit sells a screen with everything attached (including a new speaker, etc.). Since you've already replaced the screen yourself you probably don't need the toolkit that comes with the full assembly so you can choose the lower-cost option.
iFixit also offers a replacement part that let's you swap the speaker and a few other tiny parts over (for a few $ less).
Choose the replacement part that matches your comfort level and be sure to follow the instructions here.
Good luck!
Craig
Voeg je antwoord toe
Carol Tino zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 13
Altijd: 1,308
