Ga door naar hoofdinhoud
The Samsung Galaxy S5 NEO (SM-G903F) has a 5.1 inch Super AMOLED display with Full HD resolution. It's front and back cameras clock in at 5 megapixels and 16 megapixels respectively.
21 Vragen Bekijk alle
How to remotley disable FRP lock?
I have recently flashed a custom recovery on this phone. Since I forgot to disable frp lock (Re-enabled it by setting up phone after flash) it will be blocked from entering the recovery mode. for some reason it will boot-loop non stop. It will try to load the recovery then crash reboot and repeat. Thanks!
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
You need to put the phone back into download mode via holding volume down + power + home constantly and reflash the firmware or stock recovery file onto the phone.
How to flash firmware if you need it, flash with home_csc and not the non-home csc to avoid factory resetting the phone if needed:
http://updato.com/how-to/how-to-install-...
When you get phone working again go to settings, about phone, software info tap build number 7 times then go developer option and enable OEM unlock.
Was dit antwoord nuttig?
Score 3
Voeg je antwoord toe
Ethan Leroux zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 4,720
