Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
2690 Vragen Bekijk alle
restart when gaming and open big app like antutu etc
hello i get some problem for my 6s phone
when i trying big size app like (game) PUBG , Inside and antutu test , its always restart and close that app and when battrey turn to 10% my phone turn slow . please answer . what must i do guys.
Update (06/26/2018)
check this out guys
Update (06/27/2018)
can please someone explain , my battery condition is good when i look in 3utools . but why this problem dosent solved
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
u just need a new battery. apple made it so the phone slows down/shuts down if the battery cant supply proper power to the cpu
Was dit antwoord nuttig?
Score 2
6 opmerkingen:
ar u sure that because my battery not my iOS ? i watch my battery condition in setinggs thats still normal condition ?
door
there's a good chance its the battery. apple themselves are replacing batteries right now for $29 because they have acknowledged it as an issue. also the 6s is one of the best designed phones in my opinion. they rarely have board level issues besides vcc main shorts and backlight issues usually due to not disconnecting the battery before screen replacement.
door
Check your battery cycles via 3Utools which you can download and run on a windows computer or CoconutBattery which is an app run on Mac computers.
If the battery cycle exceeds 500 it definitely is overdue for a battery replacement.
Your symptoms definitely point to a worn battery. Even the OS is probably warning you about the shutdown issue if your phone is up to date.
door
guys please my new update about battery health from 3Utools
door
it seems like u replaced the battery recently if theres only 3 cycles on it. if you ordered it from ebay or amazon you probably got a defective battery. i know when i used to work for my old boss we used to order batteries from ebay and literally like 8/10 would be bad. i would suggest ordering one from ifixit or mobilesentrix as both of them sell high quality parts and I have never had an issue with a single battery form either vender.
door
1 commentaar meer tonen
Voeg je antwoord toe
iil_humm_13 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 99
