Ga door naar hoofdinhoud
The Acer Aspire One D150 is an affordable 10.5" laptop with an Intel Atom CPU. The Acer Aspire line is aimed at casual household users and covers both desktop and laptop PCs.
5 Vragen Bekijk alle
My Acer is NOT working
My ACER will not even open to the windows desktop it's stuck on PC Performance & Stability analysis report on WINDOWS TOOL and in each corner it says Safe Mode. Its getting frustrating because I cant do anything with it. HELP!!
Is dit een goede vraag?
Score 1
4 opmerkingen
I dont think my ACER is a D150 1920. Its just a KAV10 Part Num: MU.55700.020
door
Which version of Windows do you have on your computer?
door
I'm not sure which version of Windows came with this. The sticker is faded.
door
Tony Rush do you have a problem that we can help with ?
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Andrea you are in windows save mode. When you restart your computer do you get the option to start windows normally? When it first starts up in safe mode, can you got to the device manager and check on the systems icon you should see all your installed hardware. If any of them have an exclamation mark or a yellow sign check on those and best bet would be to uninstall those. I suspect you are having an issue with some hardware that windows can either not find or does not have the right driver for. Sometimes it is necessary to either reinstall Windows or repair Windows.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Andrea zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 1,560
