How to partition SSHD drive? (mac early 2015)
I bought this drive: [gekoppeld product ontbreekt of is uitgeschakeld: IF107-122] and attached it to this adaptor: [gekoppeld product ontbreekt of is uitgeschakeld: IF107-131]
It shows up in Disk Utility as Mass Storage Device Media (uninitialized)
Simple question: how to initialize it.
The Problem: The Partition button is blanked out. When I try "restore" I get the message "Restore process has failed..." with the following details:
"Validating target...
Validating source...
The volume on device "/dev/disk0" is not of type Apple_HFS or Apple_UFS
Could not validate source - Device not configured
The operation couldn’t be completed. (OSStatus error 6.)
Operation failed…"
Do I need to return this hard drive as incompatible with my computer?
MacBook Pro Retina, 13”, early 2015, OS 10.13.4
Or is there a solution?
Is dit een goede vraag?
2 opmerkingen
Your link to the adapter is pointing to the same drive as you've listed. Are you using this [gekoppeld product ontbreekt of is uitgeschakeld: IF107-131]?
Can you tell us what Mac system you have and what is the release of OS-X you are trying to install as well as from what system if different.
door Dan
Sorry about that, yes, that is the enclosure I am using. I am using MacBook Pro Retina, 13 inch, early 2015, OS 10.13.4, and am trying to install the same OSX. Thanks.
door Robert Pillers
