Ga door naar hoofdinhoud
Dell XPS 13". The smallest 13" laptop on the planet that also has the world's first virtually border-less InfinityEdge display, as claimed by Dell. Released in 2012.
144 Vragen Bekijk alle
Keyboard with water damage
My keyboard got wet and now a few keys are not working. Is the keyboard for the XPS replaceable?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
@gts112009 yes it is but a bit of a PITA. Download the maintenance manual from here Page 77 will show you how to do it. 30 Philips screws keep the keyboard attached to the palm-rest assembly (basically your top case)
Was dit antwoord nuttig?
Score 1
Before you replace the keyboard, check the Keyboard Control Board. This is just under the battery, removal is described in the manual.
I had water damage, replaced the keyboard which was a PITA, to then find out that is was the contacts on one of the sockets on the Keyboard Control Board that had failed.
Hope the helps someone!
Voeg je antwoord toe
Karl Ganshirt zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 5
Altijd: 1,016
