Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Een mini-projector voor thuisbioscopen, uitgebracht in 2016 door DBPower Electronics.
blcak dot on screen while projection
i have purchased db power t20 projector and while operating i observed that a black dot gradually occupied entire screen. kindly let me know the problem
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Filteren op:
Gekozen oplossing
I have also developed this problem. Come to find out through reading Amazon reviews that others have the same issue. It seems to be a plastic coating on the Glass piece in the projector that is being burned by the bulb. The amazon review is provided below.
Afbeelding
Afbeelding
Afbeelding
Afbeelding
Amazon Review:
Caution Maybe Fire Hazard over Long term use!
February 8, 2018
Color: Black(Classical)|Verified Purchase
Worked great for a while. A month or so after using the lens picked up a small amount of dust. Not too big but an annoyance. Now here is where it starts to get interesting. I started seeing a yellowing of the projected image. It started out really small at first and kept growing. Eventually, it became so bad I removed the projector and put up my old 3m projector back to use. I decided to take it apart to see if it was just a simple fix. Opening it up shocked me! One of the glass pieces has a piece of plastic on it that was completely burnt by the projector light. I'm talking bad like fire in your house bad. I know there is a fan in the system to keep it cool and I also verified that the fan was working properly as well. I suggest looking at another projector. Be careful if you have this projector and don't leave it running unattended!!!
Was dit antwoord nuttig?
Score 3
1 Opmerking:
does anyone know where i can order this piece of glass to replace mine that is having sa
me issue?
door Deel
Voeg je antwoord toe
SARIPALLI RAO zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 29
Altijd: 2,433
