Ga door naar hoofdinhoud
The second generation model's body has a wider track and longer wheelbase than the previous MDX. The engine was upgraded to a 3.7 liter V6 tuned for 300 hp. It accelerates from 0-60 mph in 6.5 seconds, one of the most powerful engines Honda has produced to date.
11 Vragen Bekijk alle
How to replace sunroof switch from overhead console
I need to replace the sunroof switch on my 2011 MDX from the above console but I’m not sure how to take it apart after removing the 2 main screws. I can’t seem to see what holds it back.
Any help would be appreciated.
Thanks
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
I was able to successfully replace the switch. The is 2 Philip screws in the sunglasses holder and two clips towards the sunroof. You just need to pull downward slowly and the two red clips will give. It was a faulty switch
Problem is resolved.
Hope this helps someone else. Good luck with your project .
Was dit antwoord nuttig?
Voeg je antwoord toe
x1 LbL Onetime zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 30
Altijd: 1,022
