Ga door naar hoofdinhoud
De Toyota Prius is een hybride elektrische auto ontworpen door Toyota. De derde generatie, verkocht van 2009 tot 2015, introduceerde een nieuw carrosserieontwerp met een lagere luchtweerstandscoëfficiënt.
Thermostate replacement 2014 Prius
I replaced my coolant at the dealership for my 2014 Toyota Prius at 50,000 miles . I asked the forum when you replace the thermostat . The answer was when the coolant was replaced , The dealer said they had never replaced a thermostat in a Prius . Their parts department said they had not ordered one either . Thermostats can't last forever . Is the dealer telling me the truth ? Advise ?
Is dit een goede vraag?
1 Opmerking
Thank you for your insightful answer ! Having the history of replacement of the thermostat helps me understand why its not replaced as often in other vehicles I have owned .
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
In the case of a Prius I wouldn't change the thermostat unless the car was overheating. Preventative maintenance is a good thing but in this case I would pass . The thermostat is hard to get to and requires a few hours of labor to replace. As for your statement "Thermostats can't last forever" no not forever but I know of a few vehicles with over 300000 mile that have never had theres changed . The dealer is probably being honest here . Most dealership look for ways to ding you . I would be thankful they didn't say they changed it when they hadn't and then charged you for it . Hope this helps
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
fasteddie zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 17
Altijd: 2,030
