Ga door naar hoofdinhoud
Why is the hot tub plug red hot?
Hired a hot tub today. Been plugged in for approx 6 hours in a socket in the garage. Just felt the plug and it's red hot. Very concerned as this is meant to stay plugged in all night to maintain the water temperature, but surely can't be normal? Not sure if the fault is with the plug, socket or appliance but not taking any chances. Have currently plugged it in in a different socket in my kitchen - 1 hour in its warm but not hot. Can't leave it plugged in there all night as woukd mean leaving a window open so think its going to have to be unplugged overnight unless anyone can reassure me it's safe?
Is dit een goede vraag?
1 Opmerking
Thank you. Plugged into a kitchen socket currently
door
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
Hi. Heating up water consumes a lot of power. However, a plug should not be hot to the touch for any household item, even if it's a major appliance. Power chords should be sized appropriately to the load placed on a circuit in a house. If your plug is hot to the touch, you should unplug the device immediately.
There is a chance that the load the hot tub is placing exceeds the current carrying capacity of the circuit in your garage. So the hot tub may require 30 amps, but the wiring in your garage may be only suitable for a 15a circuit. Thus, the wires in the wall in your garage are not able to carry sufficient current to the hot tub and are causing additional frictional heating of the copper wire in the wall. The wire in the wall is getting hotter than it should and it transfers this heat to anything connected to it, in this case the plug of your hot tub.
At this point, I would call an electrician for advice and or ask for an inspection of your setup.
Good luck.
Was dit antwoord nuttig?
Score 4
1 Opmerking:
The plug should have a 13A fuse in it so it shouldn’t draw any more than that
door
I have the same issue however i thought it was a faulty RDC unit as it just kept tripping (I have had external sockets fitted out side by an electrician ) it has got so bad that the fuse in the plug has blown, i had left it un plugged until today , i went to change the fuse however it had fused itself with the heat to the fuse holder.
Update (07/11/2022)
Think we need to get the electrics Checked out by a professional as nothing should over heat to this extent - and as water and electrics never mix better to be safe than sorry .
An overloaded circuit is the issue that is most likely to be the cause of hot tub plug red hot. An outlet will become overused and warm to the touch if it is having trouble supplying power to all the plugged-in equipment. An increase in heat in an electrical outlet can also be brought on by loose or broken wiring.
Voeg je antwoord toe
sallymac71 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 25
Afgelopen 30 dagen: 116
Altijd: 12,702
