Ga door naar hoofdinhoud
Model A1311 / Late 2009 / 3.06 or 3.33 GHz Core 2 Duo processor
311 Vragen Bekijk alle
Can't get past white screen at startup.
HI group,
I was given an iMac which goes to a white screen at start up and nothing I have tried gets me anywhere.
When powered up I hear the drives running, the start up chime sounds and then I get white screen and no apple logo (waited a long time). The keyboard does not light up (Caps) but I assume it is reading it because NVRAM reset chimes twice.
I have tried;
  • Starting in safe mode - no response.
  • Option + R for utilities - no response.
  • Command + Option + P + R - chimes twice but nothing after.
  • Reset SMC - nothing after.
  • Command + R - no response.
  • Made a USB boot drive - no response.
  • Attached an external display - no response.
  • Internet recovery - no response.
Additionally - I opened the machine up to take a look and discovered the previous owner had been inside also. The V Sync cable was broken (I assume not something that could cause my main issue), the hard drive had been removed at some point and I think tested (has "Good 2/2/18" on it.
Any input and ideas would be greatly appreciated, even if it's to tell me its the logic board or its the HD etc.
TIA
Paul
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Diagnostic LEDs
Depending on iMac model, there are either three or four built-in diagnostic LEDs on the logic
board that can help troubleshoot the computer. LEDs are located on bottom right edge of logic
board (under a piece of black mylar tape) and can only be seen when looking through lower
vents of rear housing.
LED Functions
LED #1
• Indicates that trickle voltage from power supply has been detected by logic board. This LED
will remain ON whenever the iMac is connected to a working AC power source. The LED will
remain on even when computer has been shut down or put to sleep. The LED will turn off
only if AC power source is disconnected or power supply is faulty.
LED #2
• Indicates that logic board has detected power from power supply when computer is
turned on. This LED will be ON when computer is turned on and power supply and voltage
regulators are working correctly.
LED #3
• Indicates that computer and video card are communicating. This LED will be ON when
computer is communicating properly with video card. If LEDs 1 and 2 are ON and you heard
the startup sound, but LED 3 is OFF, then video card might be installed incorrectly or need
replacement. Note: LED #3 is not present on models with integrated graphics.
LED #4
• Indicates that computer and LCD panel are communicating. This LED will be ON when
computer is turned on and video signal is being generated. If LED 4 is ON and there is
no image on display, then LCD panel, LED backlight board, or cables between might be
installed incorrectly or need replacement.
LED Startup Sequence
LED #1 = Power available.
If no LED is visible:
• Verify AC source
• Verify known-good AC cable is connected
• Verify cable connection between AC inlet and power supply
• Verify cable connection between power supply and logic board
• Verify power supply
LED #1 + LED #2 = Power available, and system is powered on.
If second LED is not visible when power button is pressed:
• Verify power button connection to logic board
• Verify power button functionality
• Verify logic board
LED #1 + LED #2 + LED #3 = Power available, system is powered on, and video card found.
If third LED is not visible after power on:
• Verify that MXM video card is seated properly
LED #1 + LED #2 + LED #3 + LED #4 = Power available, system is powered on, video card
found, and internal LCD found.
If fourth LED is not visible after power on:
• Verify cable connections between LCD panel and logic board
• Inspect LCD display cables for cable damage
• Verify external video functionality, and according to result check the following items:
-If external display works then verify/replace LED backlight board
-If external display works then verify/replace LCD panel
-If external display does not work verify/replace logic board
Deep Dive
Check Result Action Code
1. Verify boot chime present and fans running when system powered ON. (Reset SMC and clear PRAM if necessary for proper boot up.)
Yes
Power ON self test OK. Boot sequence started.
Go to step 2.
No
Go to Won’t Start Up symptom flow.
2. Verify if image is visible on built-in LCD panel.
Yes
Video present. Verify system functionality and return to user or jump to appropriate troubleshooting flow.
No
Go to step 3.
3. Connect supported external display. Verify if image appears on external display when system is booted.
Yes
External display detected by system. Video circuitry on logic board functional.
Inspect LVDS cable connection to back of LCD panel. Reseat and test again. If issue persists, go to Backlight Issue/No Backlight symptom flow.
No
Go to step 4.
4. Pivot enclosure to access lower intake vent, and locate diagnostic LEDs on edge of logic board. Verify if LED #3 turns on shortly after system powers on.
Yes
Logic board communicating with video card. Go to step 5.
No
If LED #3 does not turn ON
-If system has a separate video card, reseat video card and retest, then replace video card and repeat step 4. If issue persists, replace logic board.
-For a system without video card, replace logic board.
5. Locate diagnostic LEDs on logic board. Verify if LED #4 turns on shortly after system powers on.
Yes
Logic board communicating with LCD panel. Go to Backlight Issue/No Backlight symptom flow.
No
Replace LVDS cable.
Go to step 6.
6. Locate diagnostic LEDs on the logic board. Verify if LED #4 turns on shortly after system powers on.
Yes
Video controller functional and communicating with LCD panel. Go to Backlight Issue/ No Backlight symptom flow.
No
Video controller unable to communicate with LCD panel. Reseat cables first. If issue persists, replace LCD panel.
Retest.
Before replacing any board i.e. logic board etc., let us know what you get/find.
Was dit antwoord nuttig?
Score 3
4 opmerkingen:
I found the LEDs in the lower right corner and I have 3 (not 4) one stays lit while power is connected, the other 2 light up shortly after I push the power button.
door
#1 lights up with power connected. #2 and #3 light up (stay on)once you hit the power button?
door
That is correct
door
@smokeybear start with a new HDD and new cable. I think we are all over the place with this right now and do not have a know-good starting point. A new HDD and cable will provide us with such.
door
At this point getting no action with everything you tested I would say the logic board is most likely has an issue. Did you review the onboard diagnostic LED's on the main logic board?
What do they show you when you press the power button?
Score 2
17 opmerkingen:
I will look at that today, what should I be looking for? Thanks for your reply
door
Lit or not lit and the order of them going out if they do come on.
door
I am looking at the logic board on my iMac but I can't locate the LEDs, do I need to remove the logic board?
I'm also noticing what looks like an empty space where a chip should be for XDP, could that be related?
I can't add a photo to this comment unfortunately
door
I think I found the location, down in the far bottom right as the machine sits upright. I can see all 3 LEDs light up when I turn the machine on. I really appreciate your input Dan.
door
OK so after being confused by the LEDs location it appears the iMac is actually a 2009, not what I was told. Sorry for misleading the thread.
door
12 commentaren meer tonen
Voeg je antwoord toe
Paul zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 761
