Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
2690 Vragen Bekijk alle
What is the best way to test a logic board?
Hey guys,
Replacing some logic boards. One is a 5S and the other a 6S. I usually install completely and then test. Do you guys have a method to test it before installation? I.e. hook the battery, lightning port, and LCD up and test prior?
Thoughts?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Most repair shops would simply hook up a few components like the Lightning Port board, Battery, and then the LCD to test.
However, I recommend fully reassembling the 5S and 6S components (no need to screw them to the case) to test the components, since those two are quite problematic if critical components such as Touch ID aren't detected.
Was dit antwoord nuttig?
Voeg je antwoord toe
Richard Ozment zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 7
Altijd: 686
