Ga door naar hoofdinhoud
The Samsung Galaxy Note 4 is a cellular smartphone that was released in October 2014. The Galaxy Note 4 Model Number is SM-N910, SM-N910A, SM-N910T, SM-N910V, or SM-N910R4 for American variants.
256 Vragen Bekijk alle
screen lifting after replacement
Hi all,
this question is not only for note 4 but a lot of other brand phones too.
when i replace the screen, i also get adhesive sticker.
now the problem is, after i replace them, the corner of screen is always lifting, it doesn't stay stuck to the bezel.
is it because i am buying $@$*!& adhesive or am i doing something wrong?
i clean the bezel with alcohol before sticking the screen.
Is dit een goede vraag?
1 Opmerking
Thanks for the input you legends!
Will give that a go :)
Cheers
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Try adding some axtra pressure to the screen so the tape can really stick to it, if that does not work, try adding a little bit of B-7000 and add pressure to the screen.
Was dit antwoord nuttig?
Some precut adshesive already adhered to some screens is not that great. Not all tape and adhesive are equally good for sure. Ensure frame is clean as possible. Using heat before clamping can help. Heat will help create a stronger bond. I use about 270C along a side with a hot air rework station to the point where it's too hot to touch then clamp. Continue this along the perimeter of the device. If the frame is deformed, it can cause lifting and need replaced. Some techs use a tiny drop of glue at the corners.
Voeg je antwoord toe
nick zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 4
Altijd: 812
