Ga door naar hoofdinhoud
Dymo LabelManager 160 is fast, compact and lightweight, making it easy to label just about anything, anywhere. Type quickly on the computer-style QWERTY keyboard, edit with one-touch fast-formatting keys and print for perfect, professional labels every time.
Dymo Label Maker 160 How to reset double lines?
Our label maker is stuck on text setting with two lines. How do we reset it?
Have read the instructions where it isn“t told and tried "everything".
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi @ullis ,
By " tried everything" does that include a power refresh?
If not try the following:
1. Remove the batteries from the device.
2. Press and hold the power button on the label maker for about 10 seconds to remove any residual power left in the device.
3. Reinsert the batteries and turn on the device to check if this has resolved the problem.
Was dit antwoord nuttig?
Score 7
6 opmerkingen:
Thanks! Have tried to remove the batteries but not hold the power button. :)
door
Thanks! This solution worked perfectly!
door
Thanks that worked perfectly and was a great help after weeks of that function not working - Merry Christmas
door
That did the trick! Thank you .
door
Very helpful. Problem solved!
door
1 commentaar meer tonen
Voeg je antwoord toe
UlricaB zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 68
Altijd: 15,548
